INRIA
[Up]
Warning
Work in progress
This version may be updated without notice.
Active Schema Language
The Active Schema Language Specification
Working Draft 29 march 2006
Editor
Philippe Poulard  <Philippe.Poulard@sophia.inria.fr>
Copyright © INRIA
Active Schema is a powerful XML schema technology built on Active Tags technologies.
Active Schema has the ability to select its content models contextually, and to refactor them dynamically. That's why Active Schemata are active and much more efficient than other schema technologies.
Moreover, Active Schema can be used to define reusable active data type libraries that can also be used in Active Tags applications.
Requirement levels
The key words "MUST", "MUST NOT", "REQUIRED", "SHALL", "SHALL NOT", "SHOULD", "SHOULD NOT", "RECOMMENDED", "MAY", and "OPTIONAL" in this document are to be interpreted as described in RFC 2119.
Note that for reasons of style, these words are not capitalized in this document.
Active Tags specifications
The following specifications are part of the Active Tags technologies.
Table of contents
1 What are XML Schemata ?
1.1 Why another schema technology ?
1.2 What is Active Schema ?
2 Basics
2.1 Terminology
2.2 Use case
3 Active content models
3.1 Step processing
3.2 Primitive model processing
3.3 Occurrences boundaries
3.4 Material lists and exceptions
3.5 Attributes lists
3.6 Text content list items
3.7 Assertions lists
3.8 Interim processing
3.9 Reusability
4 Types
4.1 Data types
4.1.1 Using and defining data types
4.1.2 Internal data model representation
4.1.3 Parsing
4.1.4 Type inheritance
4.1.5 Semantic support
4.1.6 Functions binding
4.1.6.1 Comparison function binding
4.1.6.2 Counterpart function binding
4.1.7 Augmentation
4.2 Element classes
5 Building Active Schema
5.1 References to namespace URIs
5.2 Multi-schema support
5.3 Integration with Active Tags
5.3.1 Integration with EXP
5.3.2 Integration with Active Catalog
5.3.3 Relationship with Active Datatype
5.4 Documenting
5.5 Model inconsistency
5.5.1 Non deterministic content model avoidance
6 Processing Active Schema
6.1 Invoking Active Schema
6.2 Batch processing
6.3 Localized validation
6.4 Errors
7 ASL module reference
7.1 Elements
7.2 Foreign attributes
7.3 Predefined properties
7.4 Extended XPath functions
7.5 Externalisable features
Appendix
A Glossary
B Related Active Tags specifications
C Common Active Tags modules
D Lists
D.1 Examples list
D.2 Figures list
E Active Schemata for ASL
E.1 ASL definitions
E.2 General purpose messages
F Known implementations
An XML Schema is the expression of some assertions expected on an XML document class. Assertions on XML documents ensure that applications will process them without causing faults. Expressing assertions with schemata ensure that applications developpers will spend most of their time in designing data process and few of their time in controlling them.
Well known schema technologies are :
Name Syntax style Type Editor Specification location Elem nb
Document Type Definition (DTD) non XML syntax model based W3C http://www.w3.org/TR/2004/REC-xml-20040204/ 8
W3C XML Schema (WXS) XML syntax http://www.w3.org/TR/2001/REC-xmlschema-0-20010502/
http://www.w3.org/TR/2001/REC-xmlschema-1-20010502/
http://www.w3.org/TR/2001/REC-xmlschema-2-20010502/
42
Schematron rule based ISO http://www.ascc.net/xml/resource/schematron/Schematron2000.html 19
Relax NG (RNG) XML syntax
XML compact syntax
pattern based OASIS
ISO
http://www.oasis-open.org/committees/relax-ng/spec-20011203.html 28
Newcomer
Active Schema (ASL) XML syntax active INRIA http://disc.inria.fr/perso/philippe.poulard/xml/active-schema 20 (*)
The general purposes of a schema technology are :
  • validation : a validation process consists on checking that an input XML document is conform to the assertions expressed in the schema. Sometimes, it is possible to limit the validation on a single element.
  • structured edition : when editing an XML document, editors need to know if inserting an element, for example, is allowed in the context of the insertion.
Note
(*) 20 elements used in schema instances + 4 elements used in active sheets.
Note
Schematron, mentioned above, was designed for validation. Unlike other schema technologies, it is not obvious to use it for structured edition.
Other applications that uses schemata are emerging, such as data binding.
Any schema technology is designed to cover numbers of assertions expressed. However, the existing schema technologies can't express many constraints like the following listed below. Some technologies will cover the feature, others won't ; sometime none.
As shown in the picture below, ASL covers constraints types listed above and many others that existing schemata technologies can't.
Assertions covered by schema technologies
Active Schema is an Active Tags module, and ruled by the relevant concepts described in the Active Tags specifications.
Active Schema is a schema technology based on very simple concepts. Enhanced with Active Tags, Active Schema deals with schemata problematics with greater efficiency than other schema technologies.
An Active Schema may be used both for validation and for structured edition, and many other purposes.
With its simple concepts and low number of elements, Active Schema is easy to learn and easy to use, because the schema follows the structure of the document. An Active Schema is also friendly human-readable : it's easy to understand at first glance the content model of an element.
Finally, the capabilities of the Active Schema technology cover the following purposes :
Active Schema has been designed with the intention to keep XML document classes as is, without structure adjustment on the pretext that a content model can't be expressed with the schema technology choosen. The motivation to design an XML structure must not be lead by any schema technology.
2 Basics
Active Schema deals with XML documents representing both Active Schemata and instances through an abstract data model. XML documents representing Active Schemata and instances must be well-formed in conformance with XML 1.0 and must conform to the constraints of XML Namespaces.
An Active Schema is a flat set of definitions. The materials defined inside an Active Schema must endorse the same namespace URI, but several storage units (files) may be part of the same schema if they share the same target namespace URI.
A material definition is composed of elementary steps that are processed independently. Steps may be primitive models or step containers for others steps. Each primitive model is processed in three phases; for example, when validating:
Steps that are applied on element definitions are called active content models.
Active Schema can't constraint comments, processing instructions, and namespaces declarations obviously; however, specific assertions may restrict their usage anyway.
2.1 Terminology
Material
The term "material" is used to represent :
Content material
The term "content material" is used to represent :
Candidate material
A candidate material is the material or content material -according to the context- to check with the schema. It may be :
Additionally, a candidate material may hold the place before the first material of a list (the child nodes of an element) or after its last material ("cap candidate").
Schema client handler
A schema client handler is a component of an application that uses Active Schemata ; it processes lists of allowed material provided by the schema at runtime.
For example, a validator handler checks if the material found in the source document matches a list computed in a given step.
A schema client handler uses callbacks to process lists because it doesn't select the step to apply ; the schema engine does. Anyway, the entry point of an application that processes an Active Schema is an element, or a document ; such application should define what to do with the callbacks :
Additionally, when an element has been processed, the schema client handler may process its subelements at user option.
2.2 Use case
This use case illustrates that Active Schemata are context dependant.
In this scenario, two companies ACME and EMCA are exchanging XML documents. They are sharing the same base set of schemata, but both are extending it for special purpose usage:
The schema soup consist on a legacy DTD (without namespaces), a Relax NG schema, a brand new Active Schema, and other well known schemata for XHTML and SVG.
Scenario
Active Schema in conjunction with Active Tags offers all means to process such a case very efficiently:
Content models are element content definitions that defines which material content is allowed, when it is allowed, and how many times.
An Active Schema is a model based schema ; however, unlike other schema technologies, the models defined are active, that is to say that :
For this purpose, content models are divided in elementary checking steps, that may produce a maximum of one of the following primitive model types :
Steps set the scopes of the model types, but can also be used as step containers (with the <asl:step> or <asl:interim> elements) ; XCL can be used advantageously to control which step or substep to use. A <asl:step> element is also a container for attributes (with the <asl:attribute> element), but the list of authorized attributes must be computed in separate steps of those used for content models.
Thus, a content model is processed step by step, each step may be repeated or discarded on behalf of the following step, or on behalf of an interim step. When repeating, its content model may be kept or refactoried.
Finally, additional constraints may be computed to check the validity of an element or to check if an element can be inserted (with the <asl:assert> element).
3.1 Step processing
A step is an elementary unit of process that consists on drawing up lists of materials available and assertions. A step may be a container step, that may contain substeps, or a primitive content model step, that can't contain substeps.
When the content of an element must be checked, the steps defined in the element definition are evaluated on a global sequence. During this process, after a material (text or element) found within the element has been checked with the current step, the next material to check is then selected. According to its settings, the step used may be reused as is, refactoried, paused, or terminated ; the next step is then used.
In addition to content models, a step may also be used to draw up lists of attributes, lists of assertions, and lists of data type matchers. Attributes lists can't be mixed with content materials lists ; assertions lists can be draw up in any step ; data type matchers lists are only found within attribute definitions (<asl:attribute>) and data type definitions.
Steps and material to check are globally progressing on a synchronized reading process.
According to a given step and a given material to check, the following process is applied :
  1. if the step in use is not one of the primitive model types, its content is performed until a primitive model step is selected, or until the end of the definition (element definition, attribute definition, type definition, or class definition).
  2. the primitive model part step is used to compute the list of the allowed materials
  3. if the material matches an item of the primitive model, the step is reused, refactoried, or terminated according to its settings.
Note
When a content material must be checked for example to test if it is possible to insert an element, the host element definition must be performed step by step until the position of insertion.
Moreover :
A primitive model type is a special step used to establish a list of available material. Once selected, the model type establishes lists of allowed materials and assertions that are transmitted to the host application for candidate material checking. For example, a validator would apply these lists on the material to check (candidate material).
Once a candidate material is selected by the host application, it is used to check if it matches the material of the list :
primitive model typeapplicationrepeating
sequence (<asl:sequence>) the first material of the list may match the candidate material the list is updated
selection (<asl:select>) any material of the list may match the candidate material
choice (<asl:choice>) the list remains the same
  1. the number of times the step occurred with a matched material is checked with the min and max values given. If the number doesn't suits the boundaries, an error is raised.
To check if a candidate material matches a choice or a selection, the list is browsed sequencially ; the first item that matches the candidate material is retained. To check if a candidate material matches a sequence, the items are tested sequencially according to the occurrences boundaries.
Once a step matches a candidate material, it may be refactoried on user request if it is reused, or kept as is in the conditions of the repeating mentioned in the table above. When a list is updated while repeating, the use counter of the material is incremented ; the material used is discarded from the list if it is no longer usable, according to the occurrences boundaries set.
Once a step ends, the step container process goes on.
Occurences can be set on steps with the attributes :
Elements that allow using this attributes always use 1 as the default value for both attributes. The value "unbounded" for the @max-occurs may be specified ; otherwise, a nul or positive integer may be specified ; finally, an expression may also be specified to compute a dynamic value.
Note
Related occurs values
2 predefined properties have been defined to allow the min occurs value to be based on the max occurs value, or the contrary : $asl:min-occurs and $asl:max-occurs.
For example, min-occurs="{count(//foo}" max-occurs="{$asl:min-occurs}" is correct.
Occurences can be set only on steps. Sequences can't have occurrences boundaries (occurences are reported on the material referenced inside). Additionally, when sequences are defined... sequentially, they can be merged. A sequence is always a stable list with no occurrences boundaries.
Instead of :
    <asl:sequence>
        <asl:element ref-elem="Title"/>
    </asl:sequence>
    <asl:sequence min-occurs="0"><!-- this is invalid -->
        <asl:element ref-elem="Content"/>
    </asl:sequence>
...use the short form :
    <asl:sequence>
        <asl:element min-occurs="0" ref-elem="Content"/>
    </asl:sequence>
Occurences may be used in material reference inside select models, but grouping adjacent select models doesn't express the same model. In fact, sequence models are also slightly differents when the subactions are involving the asl:candidate() function, because the entire sequence list is evaluated with the same candidate material, whereas in the other form, it is evaluated with successive candidate material to check in the case of validation.
Occurences [FIXME: can't ???[shouldn't]] be used in material reference inside choice models, because the list is not updated.
When a candidate element has matched a material that specified occurences, the numbers of occurences are decremented for the next usage.
Element definition example
The ASL element definition below mimicks the following familiar DTD declaration :
<!ELEMENT Chapter (Title, ((Content, Chapter*) | Chapter+))>
    <asl:element name="Chapter">
        <asl:sequence>
        </asl:sequence>
        <asl:choice max-occurs="unbounded"
min-occurs="{1 - count( asl:candidate()/preceding-sibling::Content )}"
repeating="stable"> <asl:element ref-elem="Chapter"/> </asl:choice> </asl:element>
...where asl:candidate() refers to the candidate material at the position it is expected. When the choice step is involved, a <Content> element may or may not have been found. In the first case, the @min-occurs attribute will be set to 0, which denotes that the <Chapter> is optional, and in the second to 1, which denotes that a <Chapter> at least must be found. The @repeating directive of the last step indicates that both the min occurs value and the list have to be computed only once.
When involved in a stable step, occurs values are kept unchanged ; when involved in an unstable step, occurs values are actualized.
Repeating a step
If a step must be repeating, according to its occurrences boundaries, its content may be kept as is or refactoried, according to the value of the @repeating attribute :
Exiting a step
Once a primitive content model occurs the minimum times expected, it must exit as soon as the candidate material doesn't match the material, or as soon as the maximum times expected is reached.
Once a container step occurs the minimum times expected, it must exit as soon as the maximum times expected is reached, or as soon as its substeps are no longer in use.
Steps must inform that they were used with a bubble message. A primitive content model was used if a matching occurs. A container step was used if it received a bubble message that indicates that a substep was used.
A list is an ordered set of material ; as each list item may represent a group of material when a class or type reference is used, or when a namespace URI reference is used, a sublist that disables (<asl:except>) a subgroup may be added ; this sublist may also have its sublist that enables (an exception of an exception) another subgroup and so on. A sublist is defined as content or subcontent of a material.
List and sublists usage
    <asl:element name="foo"
    xmlns:bar="http://www.acme.org/bar">
        <asl:sequence>
            <!-- top list of enabled elements -->
            <asl:element ref-elem="oof"/><!-- <oof> enabled -->
            <asl:element ref-ns="bar">
                <!-- <bar:*> enabled except <bar:bar> -->
                <asl:except>
                    <!-- sublist of disabled elements -->
                    <asl:element ref-elem="bar:bar"/>
                </asl:except>
            </asl:element>
        </asl:sequence>
    </asl:element>
Of course, an exception must build a list compliant with its target list (in the example above, only elements are concerned).
An element definition may refer to attributes with the <asl:attribute> element ; an attribute reference may be expressed thanks to the @ref-attr attribute, or directly with the @name attribute for private attributes.
Thus, attribute definitions may occur on the top level elements of the schema (and shared with all schemata), or directly within an element definition ; the latters may be without a namespace URI because unprefixed attributes are "belonging" to their host element.
Hereafter, the <person> element uses an attribute defined locally :
    <asl:element name="my:person">
        <asl:attribute name="role">
            <asl:text value="author"/>
            <asl:text value="editor"/>
            <asl:text value="reviewer"/>
        </asl:attribute>
    </asl:element>
Now, it refers to a sharable and global attribute :
    <asl:attribute name="my:role">
    </asl:attribute>
        <asl:attribute ref-attr="my:role"/>
    </asl:element>
Within an element definition, more than one attribute reference or inline definition may occur ; attributes lists are separated lists which must be computed in a separate step to content models.
As attributes are unordered inside their host element, attributes references and local definitions are allowed directly under the <asl:element> element, unlike content models that must be specified within steps. Under the <asl:element> element, if attributes are encountered outside the scope of a step, they are processed as if a step were defined above ; once an explicit step is encountered, the list is applied before running the explicit step. This is important because the attributes references can't be used anymore for disabling/enabling purposes as they just have been consumed.
Only the <asl:select> primitive step is allowed for attribute lists. Once a list of attributes is established, it is applied on the element to check, or transmitted to the host application.
When validating, once an element definition ends, all its attributes must have been matched, except namespaces declarations that are not checked. The same attribute can't be matched by several lists.
Like with other materials, each list item may have a sublist, and items may be arbitrary enabled or disabled in a top list.
Additionally, items are data typed.
Global attributes are defined with the <asl:attribute> element under the root ; local attributes are defined under elements definitions. Global attributes can be used in an other schema, local attributes can't. However, within a schema, local and global attributes are reusable. Global attributes should have their names bound to namespace URI.
Attribute references or inline definition may be specified with occurrences boundaries ; static and runtime values are allowed.
As usual, the default values for both attributes is 1, which denotes that the attribute is mandatory. Hereafter an element definition references an optional attribute :
        <asl:attribute min-occurs="0" ref-attr="my:role"/>
    </asl:element>
Element content models may contain element references or text items ; Active Schema allow to define which text content is enabled, and where it is enabled, even in mixed contents.
Text content list items are very close to attribute values, except that they are unnamed items (however, a convenient way to "name" text content is to use data types) and appear exclusively in primitive content models, exactly like element references. Attribute values and text contents are text values that data types may constraint.
When processing text, comments and processing instructions are ignored, and adjacent texts are merged.
Within primitive content models, the <asl:text> element is used to introduce a text content material. When involved in a material list, a candidate material matches a text definition if and only if :
Whitespaces
A whitespace, in the sense of XML, is a text that contains spaces, tabs, and returns (carriage return, linefeed, or both).
Whitespace candidates are discarded in the following conditions : when a content model is defined with elements and texts that can contains whitespaces, if the candidate material is a whitespace followed by an element that matches an item of the content model, then the whitespace candidate is ignored.
Text matchers
A text item uses the same matchers than those used to define data types and those used in attribute values. A text definition involves the <asl:text> element with :
However, as they may be mixed with element references, only a single matcher can be used at a time, that is to say that 2 text matchers can't be found side by side. When a choice of text matcher is needed, it must be enclosed within an inline type definition, or defined with a type reference. Schemata designers must take care that a step that ends with a text matcher can't be followed by a step that begins with a mandatory text matcher, because the last text matched has been totally consumed by its matcher.
Here is an element that must contain one string beyond a predefined set :
    <asl:element name="Role">
        <asl:choice>
            <asl:text min-occurs="0" value="author"/>
            <asl:text min-occurs="0" value="editor"/>
            <asl:text min-occurs="0" value="reviewer"/>
        </asl:choice>
    </asl:element>
...and another that may contain any string :
    <asl:element name="Para">
        <asl:choice>
            <asl:text ref-type="xs:string"/>
        </asl:choice>
    </asl:element>
A mixed content may also be defined :
    <asl:element name="p">
        <asl:choice max-occurs="unbounded">
            <asl:text min-occurs="0" ref-type="xs:string"/>
            <asl:element min-occurs="0" ref-elem="b"/>
            <asl:element min-occurs="0" ref-elem="i"/>
            <asl:element min-occurs="0" ref-elem="span"/>
            <asl:element min-occurs="0" ref-elem="tt"/>
            <asl:element min-occurs="0" ref-elem="a"/>
        </asl:choice>
    </asl:element>
A content model may precisely indicates where and which text content is allowed :
    <asl:element name="Person">
        <asl:choice>
            <asl:text min-occurs="0" value="Mrs"/>
            <asl:text min-occurs="0" value="Ms"/>
            <asl:text min-occurs="0" value="Mr"/>
        </asl:choice>
        <asl:sequence>
            <asl:element ref-elem="Name"/>
        </asl:sequence>
    </asl:element>
...that could match :
<Person>Mr<Name>Poulard</Name></Person>
...but can't match :
<Person>Mr<Name>Poulard</Name> is french.</Person>
When used directly, the <asl:text> element allow to express simple rules ; for more complex text combinations, the reference to a <asl:type> offers much more flexibility. For example, both following text contents :
<polygon>x=6, y=10, x=37, y=61, x=37, y=16</polygon>
<polygon>6, 10, 37, 61, 37, 16</polygon>
...could be defined by the following schema that refers to a custom data type :
    <asl:element name="polygon">
        <asl:choice>
            <asl:text min-occurs="0" ref-type="my:points"/>
        </asl:choice>
    </asl:element>
The definition of this type is shown in the chapter about data types. Notice that a type may be used indifferently in a text content or in an attribute value :
        <asl:attribute name="points" ref-type="my:points"/>
    </asl:element>
A type may also be defined anonymously (and can be used also for attributes definitions) :
        <asl:choice>
            <asl:text>
                <asl:type>
                    <!-- insert the type definition here -->
                </asl:type>
            </asl:text>
        </asl:choice>
    </asl:element>
Please refer to the chapter about data types.
Assertions lists are separated lists than can be computed at each step. Once a list of assertions is established, it is applied on the element to check, or transmitted to the host application.
Assertions are additive controls that can't be expressed by content models. Assertions are defined with the <asl:assert> element. Its @test attribute contains an expression that must return true on valid datas, false otherwise. If the assertion to test can't be expressed within this single attribute, its subactions are performed, and the assert is true if the current object is evaluated to true, false otherwise.
For example, the following assertion limits the deepest of an element :
        <asl:assert test="{ count( asl:element()/ancestor::Chapter ) < 4 }">
            <asl:desc>Too much nested chapters !</asl:desc>
        </asl:assert>
    </asl:element>
The asl:element() function returns a reference of the element currently tested.
The <asl:interim> element defines a step that marks a pause on the current model in use. It allows other content models to be applied, but other special purpose processing may be intend. When ending, the model in pause goes on.
An interim step is an unstable step launched only when its host model matched.
    <asl:element name="foo">
        <asl:choice max-occurs="10" min-occurs="5">
            <asl:element ref-elem="bar"/>
            <asl:element ref-elem="goo">
                <asl:interim>
                    <asl:sequence>
                        <asl:element max-occurs="2" min-occurs="2" ref-elem="hoo"/>
                        <asl:element max-occurs="3" min-occurs="3" ref-elem="woo"/>
                    </asl:sequence>
                </asl:interim>
            </asl:element>
        </asl:choice>
    </asl:element>
Each time the <goo> element will be matched, the sequence of <hoo> and <foo> must be applied, as shown in the instance above which is valid with the schema.
<foo>
    <bar/> <!-- 1st choice -->
    <goo/> <!-- 2nd choice -->
    <!-- interim model starts -->
    <hoo/> <!-- 1st occur of the 1st elem -->
    <hoo/> <!-- 2nd -->
    <woo/> <!-- 1st occur of the 2nd elem -->
    <woo/> <!-- 2nd -->
    <woo/> <!-- 3rd -->
    <!-- interim model ends -->
    <bar/> <!-- 3rd choice -->
    <bar/> <!-- 4th choice -->
    <bar/> <!-- 5th choice -->
</foo>
Warning
This structure is somewhat unusual in other schema technologies : when a content model is defined within an element referenced, it means that this content model is applied on the children of the candidate element.
The <asl:interim> element denotes that the content models defined within are applied on the next sibling candidate elements.
Set of attributes
There is no structure that defines groups of attributes in Active Schema, but it is possible anyway to select one set or another with an interim step : once an attribute matched, an additional attribute list may be provided.
Separate attributes sets
The following snippet schema express that wether the a, b, and c attributes must be present together, or the d and e attributes must be present together.
        <asl:select>
            <asl:attribute min-occurs="0" ref-attr="a">
                <asl:interim><!-- an interim step is always unstable !!! -->
                    <asl:select max-occurs="2" min-occurs="2">
                        <asl:attribute ref-attr="b"/>
                        <asl:attribute ref-attr="c"/>
                    </asl:select>
                </asl:interim>
            </asl:attribute>
            <asl:attribute min-occurs="0" ref-attr="d">
                <asl:interim><!-- only one item : don't mind about instability -->
                    <asl:attribute ref-attr="e"/>
                </asl:interim>
            </asl:attribute>
        </asl:select>
    </asl:element>
Mixed sets and stacked interim processes
An interim step may be advantageously used for complex combination descriptions. It is possible to define an interim step that occurs when an element has been matched, but that draw up an attribute list, or the opposite. It is also possible to define an interim step inside an element or attribute that have been involved in another interim step.
Restrictions
As the <asl:attribute> element is used both to define an attribute and to refer to one, the <asl:interim> element must be used without causing a conflict. This can be avoid only when using it on attribute references. On the other hand, attribute definitions can't contain the <asl:interim> element.
An <asl:interim> step can also be used within text and type definitions. In this case, its substeps must deal exclusively with text and type matchers. More generally, an interim step must not be used to check additional constraints on attributes or elements because a text parsing is currently in course and may fail without causing fault because another text parsing may suit later. It would be too problematic to deal with possible additional constraint checking in the case where a type, for example, relies on another type which could match whereas its parent type doesn't.
Interim tuning
The @replace attribute indicates if the interim model replaces or not the host model :
Replacement with an interim model
        <asl:sequence>
            <asl:element min-occurs="0" ref-elem="Content">
                <asl:interim min-occurs="0" replace="all">
                    <asl:sequence>
                        <asl:element max-occurs="unbounded" min-occurs="0" ref-elem="Chapter"/>
                    </asl:sequence>
                </asl:interim>
            </asl:element>
            <asl:element max-occurs="unbounded" ref-elem="Chapter"/>
        </asl:sequence>
    </asl:element>
If the <Content> element is matched, the rest of this sequence will be ignored ; instead, the inner sequence where the <Chapter> element is optional will be applied.
If the <Content> element is not matched, the rest of this sequence will be applied as usual.
When an interim step replaces definitively an upper model, this model is discarded without further occurrence boundaries checking.
3.9 Reusability
Numbers of ASL elements have an @id attribute that identifies the element with a qualified name.
Any identified attribute may be reused thanks to the <asl:use> element. The @scope attributes indicates if the target element must be used itself, or only its content (by default).
Additionaly, when only a part of a definition would be convenient to reuse, the <asl:block> element can be use to set the boundaries of the reusable part. For other ASL elements, the <asl:block> element is totally neutral (it is traversed as if there were only its content). When using a group, the scope must be set to the content.
Note
ID scope
It is strongly recommended for identifiers to be qualified names ; the namespace URI of identifiers should be the same of the target namespace URI of the host schema.
An ID bound to a namespace URI is looked up within the set of schemata bound to the same namespace URI.
For example, the ASL schema for OASIS XML Catalog uses this elements.
4 Types
Types differ whether they are related to textual datas or elements. This specification talks about data types (<asl:type>) or element classes (<asl:class>).
Warning
Notice that the Active Datatype specification talk also about objects types that are not relevant in this specification.
4.1 Data types
Data types apply both on attribute values and text content, designated as textual data. A textual data is a string that can be parsed into a typed data. Parsing a textual data is the operation that consist on sequencially converting the characters into the typed data according to a data type. A typed data consists on:
Data types may be composite, that is to say composed of sequences of data types. Once the first data type of the sequence ends to parse the textual data, the second try to parse the remainder, and so on.
From the point of view of an attribute or a text content, the parsing succeeds if and only if a typed data has been parsed succesfully with no remainder. That is to say that if the data type is a composite data type, the last data type of the sequence must consume all the remainder, otherwise the entire parsing fails.
Defining new data types
Active Schema provides means to define new data types, for example by adding constraints on an existing type, like W3C XML Schema does. It is possible for example to restrict the values of an integer to be between 1 and 365.
When defining a data type, it is possible to apply constraints during or after parsing. Constraints may be applied on the lexical value and/or the logical value and its components (see internal data model representation).
A data type can be defined with a name with the <asl:type> element and its @name attribute, or anonymously directly where it is needed. Named data types are easily reusable. Anonymous data types should be designed for single shot usage.
Named types are defined at the top level with the @name attribute of the <asl:type> element. Anonymous types are defined anywhere a type is expected without its @name attribute. When a type is expected, it is defined anonymously, or referred to by its name with the @ref-type attribute of the <asl:attribute> and <asl:text> elements.
Data types are defined on behalf of :
The same type definition may be referred both in an attribute value and in a text content.
For example, the following type definition is reusable :
    <asl:type name="asl:min-occurs">
        <asl:choice>
            <asl:text ref-type="xs:nonNegativeInteger"/>
            <asl:text ref-type="adt:expression"/>
        </asl:choice>
    </asl:type>
The above definition is explicitely a choice step ; the first type that matches the text value is kept.
If an attribute is defined with a single type, its definition uses the @ref-type attribute. Otherwise, this attribute is missing and the content of the attribute definition may refer to a list of types. The attribute definitions below are equivalent; the former uses a type that aggregates those that the latter uses directly:
    <asl:attribute name="min-occurs" ref-type="asl:min-occurs"/>
    <asl:attribute name="min-occurs">
    </asl:attribute>
The attribute definition act as a choice step ; the first type that matches the attribute value is kept.
The last mean to define a type, is to extend an existing type, by using the @base attribute, to specify which type it is based on.
    <asl:type base="xs:integer" name="xs:nonNegativeInteger">
        <!-- type definition here -->
    </asl:type>
The definition consists on steps that use matchers.
As explained hereafter, a type may be :
A composite data is a typed data produced by a composite type, that is to say, a typed data that may contain other typed datas. A non-composite data such as an xs:int is a typed data with a single value; it can't contain other typed datas.
The formal type of a composite type is adt:XComponent.
A typed data is a cross operable object for which its attributes contains characteristics of the type for the specific value (facets), and its children contain the parsed datas (values).
When parsing a text value, the engine try to build an internal data model ; the parsing fails when the target object fails to construct, or if some additional assertions -introduced with the <asl:assert> element- fails. Otherwise, the parsing succeeds.
Runtime data types are parsed as expressions, and the object expected can be retrieved only at runtime ; thus, errors may be raised at runtime. Runtime data types are involved thanks to the adt:expression type. Notice that at runtime, an adt:expression may also return non XML-aware objects; the type of such objects, known as marker types, are out of the scope of this specification. Please refer to the Active Datatypes specification for further information.
The parsing result may be constructed with the help of other types ; in this way, the data model obtained may be any arbitrary complex structure. Active Schema provide the <asl:item> element to build a made-to-measure data model. When built with Active Schema actions, a text value is always parsed to a typed data that is a cross operable object.
For example, the fr:date type could be defined to parse a value such as 10 juin 1969, and return an object that could be accessed thanks to XPath ; in the context of its value :
Facets
Facets are attributes exposed in addition to the data model. They have a name and a value that is not necessary a string, and can be constraint.
For example, an xs:integer have the facet @adt:total-digits that contains the number of digits of the integer. An assertion on this facet could be set like this :
    <asl:assert test="{ @adt:total-digits < number(2) }"/>
Note
WXS datatypes are exposed in Active Tags in a slightly different manner than in the W3C XML Schema specification, because the base concepts are somewhat different, specifically on the hierarchy model. However, as the same features are covered and as they share the same semantics, they are compatible. Active Tags just provides a different view of the WXS datatypes.
The Active Datatypes specification describes how WXS datatypes can be used in Active Tags. In particular, it names the WXS facets to use as attributes in typed datas.
The core facets are :
Note
The facets are bound to the http://www.inria.fr/xml/active-datatypes namespace URI for convenience : typed datas may have their own attributes (user defined) that can't be in conflict with the facets.
The value of the object itself may be used to express constraints. For example, to constraint an integer to be less than or equal to 31 :
    <asl:assert test="{ value( . ) <= number( 31 ) }"/>
4.1.3 Parsing
Text parsing is very close to content model parsing : many Active Schema elements (<asl:choice>, <asl:except>, <asl:interim>...) are accomplishing the same function for text parsing that for content model parsing. The difference is that the material used to feed the context are related to text :
Matchers and composite types
A type definition uses text matchers that are text values, regular expressions or other type definitions that define which character sequences are allowed in the type definition. When all matchers expected in a type definition has been involved and that a character sequence remains, the type returns the result data model with a remainder. If the host material that was using this type definition is itself a type definition, the host type goes on applying the matching with the remainder, and so on until the host is an attribute definition or a text content model. At this stage, if the remainder is involved in the next type or matcher, the process is repeated. When the host attribute or text content model definition definitively ends, the remainders must have been consumed. Otherwise, the matching fails.
A text matcher is involved with the @value, @match, or @ref-type attributes of the <asl:text> element :
Finally, if the <asl:text> element has none of the above attributes, the type definition used will be the first found in the context after running the element content, otherwise it won't match anything.
Text matchers may be optional, and may be repeated. The repetition may be specified with the @min-occurs and @max-occurs attributes.
Warning
Repetitions may be impossible to process without the help of separators that are not involved in the matching process.
For example, 123456 can't match two xs:integer whereas 12,3456 can match one xs:integer, the "," separator, and another xs:integer. If the type my:twoDigits was defined to match two digits, then 123456 could match three my:twoDigits.
However, my:twoDigits could work as explained above only if it doesn't rely on an xs:integer, constraint by an aditionnal assertion set on its facets, like this:
    <asl:assert test="{ @total-digits < number(2) }"/>
Typed data items
The following sequence definition is used to match x=12,y=34 but not x=,y=34 :
    <asl:sequence>
        <asl:text ignore="yes" value="x="/>
        <asl:text ignore="yes" value=",y="/>
    </asl:sequence>
The @ignore attribute is used to specify that the value matched is not used to build the result data model. The others matched character sequences are used to build the result data model as unnamed items which are of the type xs:nonNegativeInteger in this example.
To build the data model with a named item, or to compute a value other than those matched, the @item-value and @item-name attributes may be used :
    <asl:text item-name="x" item-value="{current()}" ref-type="xs:nonNegativeInteger"/>
As shown above, the current object is set to the matched value before item creation.[FIXME: not sure, remove it ?[ After, the previous value of the current object is restored.]]
Additionally, this attributes (@item-value and @item-name) may be separated ; in this case, the next matched value that follows a matched value that indicates an item name, must specify an item value.
    <asl:text item-name="x" value="x="/>
    <asl:text item-value="{current()}" ref-type="xs:nonNegativeInteger"/>
In short, a matched content may be :
Finally, the result data model may be construct with arbitrary additional items with the <asl:item> element, and optionally its @name attribute. When encountered, this element wraps in a composite data (its type is adt:XComponent) all subitems produced; if empty, the item is not created.
    <asl:item name="point">
        <asl:sequence>
        </asl:sequence>
    </asl:item>
Initializing the internal data model
The @base attribute of a type definition (<asl:type>) indicates that the type is based on another type, called the base type. The base type is used to parse the input text data before using the inner type definition. The type definition may indicate how to initialize the typed data and how to parse further.
For this purpose, the @init attribute indicates how to initialize the typed data ; when present, it contains an expression that will be computed to initialize the typed data ; common usage are explained below :
In any case, the current object is set to the typed data produced by the base type. Additionally, the $asl:data property is set to the initialized typed data. While parsing, the typed data initialized may be updated or its content appended if it is a composite data; it can be referred thanks to the $asl:data property.
The @parse attribute is involved after the @init attribute to indicate which text data will be used for the parsing. If missing, the type will parse the remainder that has not been parsed by the base type. Otherwise, it contains an expression that will return the text to parse.
Note
When the @base attribute of a type definition is missing, it is equivalent to set the base type to xs:string, the @init attribute to "void", and the @parse attribute to "{.}" : the effect is that the entire text value is parsed with the type definition.
For example, the following type is based on an integer:
    <asl:type base="xs:int" init="{.}" name="temperature">
        <!--temperature stuff here-->
    </asl:type>
A typed data created by this type is of the xs:int type; the inline part of the definition was parsing the remainder, if any (the @parse attribute is missing).
The following type will remove undesirable spaces from the input text value before choosing which text has been selected :
    <asl:type init="" name="size" parse="{asl:compacted-string(.)}">
        <asl:choose>
            <asl:text value="big"/>
            <asl:text value="small"/>
        </asl:choose>
    </asl:type>
In this example, the remainder -if any- is also cleaned of trailing spaces.
[FIXME: what about an optional attribute item-name='name' to do things like for asl:text ?]
Building the internal data model
When parsing, each time a matcher has matched, the typed data matched is set as the current object, that the matcher can refer to build the data model if the @ignore attribute is not set to "yes". For example, the following text matcher builds an item with the name "x" and which value is the typed data given by a text parsed as a non-negative integer :
When the item of the data model has been built, it is set to the $asl:data property if it does not exist, or appended to its child if it already exists. This property is a cross-operable object that can be referred while building the data model.
The $asl:data property in one hand and the current object in the other hand are not handling the same datas : the current object handles the last parsed data, whereas the $asl:data property handles the previous one; if the last parsed data is not ignorable, it is appended to the $asl:data property and became the new $asl:data property if it is a composite data. Once the composite data ends to parse, its parent will be restored as the $asl:data property.
Each time the <asl:item> element is encountered, a new empy typed data (its type is adt:XComponent) is appended to the $asl:data property (which is replaced too as explained above). Its subactions will define its content. After running them, if the current typed data is still empty, it is removed. In short, empty items are ignored.
Each time an item name and an item value are encountered, they complete the typed data with a single named item.
Example
Polymorphic attribute value
In this example, one defines an attribute value that both matches the following kind of content :
<polygon points="x=6, y=10, x=37, y=61, x=37, y=16"/>
<polygon points="6, 10, 37, 61, 37, 16"/>
The schema below parses such attribute values with an anonymous type :
        <asl:attribute name="points">
            <asl:type init="{adt:XComponent()}" parse="{asl:compacted-string(.)}">
                <asl:item id="pointXY-item">
                    <asl:sequence>
                        <asl:text ignore="yes" min-occurs="0" value=" "/>
                        <asl:text item-name="x" item-value="{.}" ref-type="xs:nonNegativeInteger"/>
                        <asl:text ignore="yes" value=","/>
                        <asl:text ignore="yes" value="y="/>
                        <asl:text item-name="y" item-value="{.}" ref-type="xs:nonNegativeInteger"/>
                    </asl:sequence>
                </asl:item>
                <asl:sequence>
                    <asl:text ignore="yes" min-occurs="0" value=",">
                        <asl:interim min-occurs="0">
                            <asl:use ref-id="pointXY-item" scope="global"/>
                        </asl:interim>
                    </asl:text>
                </asl:sequence>
            </asl:type>
                <asl:item id="point-item">
                    <asl:sequence>
                    </asl:sequence>
                </asl:item>
                <asl:sequence>
                            <asl:use ref-id="point-item" scope="global"/>
                        </asl:interim>
                    </asl:text>
                </asl:sequence>
            </asl:type>
        </asl:attribute>
    </asl:element>
The schema reports that in the following snippet XML, the two first polygon definitions are valid, the two last invalid.
    <polygon points="x=6, y=10, x=37, y=61, x=37"/><!-- "y" value missing -->
    <polygon points="6, 10, x=37, y=61, 37, 16"/><!-- heterogeneous value pairs -->
Notice that the last polygon definition is invalid, but it is still possible to design a schema that allow heterogeneous value pairs.
The same internal data model built for the 2 first polygon definitions is represented below :
[TODO: change in this picture adt:item with adt:XComponent]
The content model may also be slightly modified thanks to an interim step and XCL :
...will produce a named item accessible with ./*/x, whereas :
    <asl:text ignore="yes" ref-type="xs:nonNegativeInteger">
        <asl:interim>
            <xcl:attribute name="x" value="{current()}"/>
        </asl:interim>
    </asl:text>
...will produce an XML attribute accessible with ./*/@x.
Any artifact other than a matcher put in the context will be used to build the typed data.
Matchers order
As matchers are tested sequencially, order is significant when lexical values are overlapping.
For example, the lexical values of xs:boolean are "true", "false", "0", "1" ; the two last are also in the lexical values of xs:integer ; the following types may not give the same typed data :
    <asl:attribute name="booleanOrInteger">
        <asl:text ref-type="xs:boolean"/>
        <asl:text ref-type="xs:integer"/>
    </asl:attribute>
    <asl:attribute name="integerOrBoolean">
    </asl:attribute>
"1" will return a xs:boolean with the first type, and an xs:integer in the second.
Warning
This is paricularly important when the xs:string type is involved, because any textual data is at least a string. When involved, this type should always appear at the end of a definition.
The xs:string type may be used as a fallback type.
When a type is defined, it may be based on another type. In this case, the value of the upper type becames the value of the new type defined. Additional items may be produced with the remainder of the upper type. Assertions can be used to restrict the scope of the values of the upper type.
For example, the polygon type defined previously may be used to define a triangle type and a square type :
    <asl:type name="polygon">
        <!-- the definitions used in the previous example -->
    </asl:type>
    <asl:type base="polygon" name="triangle">
        <asl:assert test="{count( ./* ) = 3}"/>
    </asl:type>
    <asl:type base="polygon" name="square">
        <asl:assert test="{count( ./* ) = 4}"/>
        <!--insert other assertions to check the angles-->
    </asl:type>
Active Schema may cover the data value semantics, and comparison between values expressed in different lexical spaces is possible ; for example, which temperature is colder than the other ? "31°F" or "0°C" ?
        <asl:choice>
            <asl:text ignore="yes" min-occurs="0" value="°C"/>
            <asl:text ignore="yes" min-occurs="0" value="°F">
                <asl:interim>
                    <xcl:update operand="{ (. - 32) * 5 div 9 }" referent="{$asl:data}"/>
                </asl:interim>
            </asl:text>
        </asl:choice>
    </asl:type>
As shown above, a typed data is initialized with an xs:int (init="{.}" keeps the typed data given by the base type). The remainder is parsed according to the inner declarations. When the string "°F" matched, the value stored previously is updated with the <xcl:update> element.
Functions may be bound to a type for the following purposes:
Functions are bound to a type by naming them in the type definition with attributes:
    <asl:type compare-with="geom:compare-polygon" name="geom:polygon"
parse-with="geom:polygon"> ... </asl:type>
EXP may be used advantageously to define such functions, specifically when functions are defined as macro functions. See integration with EXP.
The @compare-with attribute contains the qualified name of a function involved for comparison. This function is automatically invoked with 2 arguments. When an XPath expression uses a comparator, like $poly1 <= $poly2, the type of the first argument $poly1 determine which function to call. Then the function associated is called with the 2 arguments in parameters. If necessary, the second argument may be cast to the same type of the first argument before invoking the function. The function involved return a number that is 0 if the arguments are equal or not comparable, negative if the first argument is less than the second one, or positive if the first argument is greater than the second one.
When this attribute is missing, the arguments are compared as indicated in the XPath specification.
EXP may be used advantageously to define such functions. Moreover, several comparison functions may be defined, and each application is free to use which comparison function to use. For example, what to compare when 2 polygons are compared ? The number of points ? The area ? The perimeter ? See integration with EXP.
This function is those which will be used for casting operations.
[TODO]
4.1.7 Augmentation
When typed datas are parsed while validating an XML document, it is often usefull to bind the typed data to the nodes on which a type is defined. For example, if an attribute is defined as a xs:date the typed data bound to it will reflect this type, which can be very usefull when ordering relationships occur : a sort on a set of such attributes should be performed on the typed data, not on the string value of the attribute. The mechanism that allows to bind a typed data to an XML node is called "data augmentation" which consists on augmenting the amount of informations of the XML document on its infoset (which is also often referred to "Post Schema Validation Infoset", or PSVI).
Active Schema allows to augment the amount of informations of an XML document while validating on user request. In this case, comparison operations made with XPath or functions that imply an order relation between item such as a sorting function must apply on the bound typed data, not on the raw textual data.
As the schemata in use are generally defined by the processor instance involved when validating, several different typed data might be bound to the same node ; those to consider is those set by the same processor instance that performs the validation. In other words, typed datas are bound to nodes in the scope of a processor instance. As the <asl:validate> element allows to define locally a schema not known by the processor instance (or more precisely by its catalogs), it is not recommended to perform several validation on the same parsed XML document within the same processor instance with different schema instances. In this case, the last schema applied will bind new typed data if it redefines them ; others typed data will remain the same.
Augmented datas must be taking in charge in Active Sheets ; non Active Tags applications such as XSLT are encouraged to do so.
The @augment attribute of the <asl:validate> element indicates whether typed datas must be bound to nodes defined with a type or not.
Infoset augmentation with a typed data
In this example, a weather report indicates town temperatures expressed in °C as well as in °F. The type of the @temp attribute is those defined in a previous example.
<weather-report>
    <town date="2005/09/09" name="Paris" temp="21°C"/>
    <town date="2005/09/08" name="Paris" temp="22°C"/>
    <town date="2005/09/09" name="Vladivostok" temp="32°F"/>
    <town date="2005/09/07" name="Paris" temp="20°C"/>
    <town date="2005/09/08" name="London" temp="23°C"/>
</weather-report>
The following snippet code simply parse the XML file, and validate it with the schema within which the expected type is defined ; then the towns are displayed in temperature order thanks to the xcl:sort() function :
    <xcl:parse name="wr" source="file:///path/to/weather-report.xml"/>
    <asl:validate augment="yes" node="{ $wr }" schema="file:///path/to/schema.asl"/>
    <xcl:for-each name="town" select="{ xcl:sort( $wr/weather-report/town, @temp ) }">
        <xcl:echo value="{ $town/@temp } { $town/@name } { $town/@date }"/>
    </xcl:for-each>
Output :
32°F Vladivostok 2005/09/09
20°C Paris 2005/09/07
21°C Paris 2005/09/09
22°C Paris 2005/09/08
23°C London 2005/09/08
As expected, 32°F is placed before 20°C. If the @augment attribute of the <asl:validate> element was set to false, the temperatures will be sorted in lexical order, so 32°F would be placed at the last position. To force a lexical order on the augmented infoset, it is also possible to wrap the sort criterion with the string() function : string( @temp ).
4.2 Element classes
[TODO: Distinct 'element classes' and 'structures' : the former are like substitution groups, the latter are related to typed elements]
All materials defined within an Active Schema must be bound to the target namespace URI declared by the @target attribute of the root element, <asl:active-schema>. When an XML document is a mix of materials bound to several namespaces URI, each namespace URI for which the bounded materials need to be controlled must have its own schema.
<?xml version="1.0" encoding="iso-8859-1"?>
<asl:active-schema asl:version="1.0" schema-version="1.0" target="acme" xmlns:asl="http://www.inria.fr/xml/active-schema" xmlns:acme="http://www.acme.com/my-schema"> <!-- acme material definitions here --> </asl:active-schema>
Many elements are used for both defining a material or refering to a defined material (<asl:element name="..."> and <asl:element ref-elem="...">). Sometimes, the reference to a material may be inline, sometimes it can't. That's the case of elements that are always referred to definitions located on the top level. On the opposite, attributes, types, and text definitions are not obliged to be located on the top level, and then can be used as inline references.
Many informations inside an Active Schema deals with namespace URIs ; instead of pointing out directly namespace URIs, which are generally long strings, Active Schema always uses a prefix bound to a namespace URI as a more convenient mean.
For example, the @target attribute of the schema is a prefix ; the @ref-ns attribute in attribute and element references is also a prefix.
As usual with XML namespaces, only the bounded namespace URI matters. Schema designers must define the appropriate namespaces declarations when they are using prefixes in attributes values.
Namespace references
The @ref-ns attribute in attribute and element references is a prefix bound to a URI. However, the special following prefixes may be used to refer to namespaces that have a contextual role :
  • #any : any non-empty namespace URI
  • #other : any non-empty namespace URI different of those specified in the host schema
  • #local : stands for unbounded material
Note
The ##targetNamespace used in W3C XML Schema has not its equivalent in Active Schemata ; users just have to use the same prefix as those specified in the @target attribute of the root element.
The xml prefix may also be specified without any particular precaution (the appropriate namespace declaration is always auto-declared). On the contrary, the xmlns prefix must not be specified ; Active Schema can't constraint namespace declarations because they have a particular meaning in XML.
Active Schema may be mixed with other schemata technologies to add constraint types not supported. The schemata supported are implementation dependant.
Moreover, legacy schemata doesn't necessary deal with foreign material inclusion in XML instances ; elements and attributes that belong to other namespaces and that was not plan to be present will be normally forbidden.
Active Schema allow to "patch" existing schemata (of course including Active Schemata), in order to :
This is particularly interesting when users are dealing with several third-party schemata that has not been written to accept materials in foreign namespaces.
Schemata patching
A company uses multiple schema instances at different level :
  • shared public schemata
  • corporate general schemata
  • application specific schemata
Each level registers its schemata in a catalog.
In this example, an element is defined at the top level with a legacy public DTD that contains :
<!ELEMENT acme:order (acme:ship-to, acme:item*)>
<!ATTLIST acme:order xmlns:acme CDATA #FIXED "http://www.acme.com/order"
                     id         CDATA #REQUIRED>
The company needs to patch the DTD to allow XHTML content to be inserted inside <acme:order>. A catalog at the intermediate level simply refers to the following schema :
<asl:active-schema asl:version="1.0" schema-version="1.0" target="acme" xmlns:asl="http://www.inria.fr/xml/active-schema" xmlns:acme="http://www.acme.com/order" xmlns:xhtml="http://www.w3.org/1999/xhtml"> <asl:element name="acme:order"> <asl:apply-definition> <asl:fallback match="xhtml:*" mode="ignore"/> </asl:apply-definition> </asl:element> </asl:active-schema>
As this schema is registered in a catalog close to the application, it will be used first. The <asl:apply-definition> element indicates to use the next schema in the catalog list, that is to say the DTD. The <asl:fallback> element is used when an unexpected attribute or element is encountered when applying the definitions. Its @mode attribute indicates if it has to be ignored, skipped, or traversed.
If the XHTML content had to be inserted inside <acme:order> and before <acme:ship-to>, the element definition would be simply :
        <asl:sequence>
            <asl:element max-occurs="unbounded" min-occurs="0" ref-ns="xhtml"/>
        </asl:sequence>
        <asl:apply-definition/>
    </asl:element>
An application of that company have to deal with a new attribute (@date). Moreover, the order ID follows a specific text structure. Once again, a new schema is registered in the application's nearest catalog :
<asl:active-schema asl:version="1.0" schema-version="1.0" target="acme" xs:version="1.0" xmlns:asl="http://www.inria.fr/xml/active-schema" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:acme="http://www.acme.com/order"> <asl:type name="acme:id"> <!-- type definition here --> </asl:type> <asl:element name="acme:order"> <asl:attribute name="date" ref-type="xs:date"/> <asl:attribute name="id" ref-type="acme:id"/> <asl:apply-definition/> </asl:element> </asl:active-schema>
Multiple definitions
Schemata are organized in an ordered list ; each item of the list is given by a catalog (a single catalog may deliver several items). Schemata are ordered in the order they are delivered by catalogs.
When an element refers to an attribute that is already referred in a schema that has a less priority, the attribute must be checked only once : the schemata that has a less priority must not check it.
When a specific schema "overrides" a definition (attribute, element, type, etc), those used must be those that overrides even if it is referred from a schema that has a less priority. For example, if an attribute definition uses a named type defined in the same schema instance, but another schema instance that has a higher priority redefines this type and preserve the attribute, the attribute will be checked with the redefinition of the type.
Active Schema is part of Active Tags technology and then, fully integrated to Active Tags features. Particularly, any other module may be used in a schema.
One of the most useful module may be XCL, because it offers the ability to go further with a procedural approach where the ASL declarative model find its limits. For example, an interim step could be optional by putting it inside an <xcl:if> statement ; schemata designers should use such features when they can't express a @max-occurs constraint on a single expression. Anyway, XCL enhance the power of Active Schema because it may be used to build contextual lists of materials.
Modules that provide accesses to remote data sources may be also very useful.
Attribute constraint with SQL
In this example, the RDBMS module allow to dynamically draw up a list of values available in an attribute.
    <asl:attribute name="product"
    xmlns:rdbms="http://www.inria.fr/xml/active-tags/rdbms">
        <asl:type parse="{asl:compacted-string(.)}">
            <rdbms:connect db="products-db" driver="..." host="..." name="products-db" passwd="..."
user="..."/> <rdbms:select connexion="{$products-db}" name="products"
query="SELECT * FROM orders WHERE id={asl:element()/@category}"/> <asl:choice> <xcl:for-each name="product" select="{$products}"> <asl:text value="{$product}"/> </xcl:for-each> </asl:choice> </asl:type> </asl:attribute>
Design
As explained in "managing Active Schema", many storage units can be used to build a schema. This feature is particularly useful when a schema is intended to be shared with third-parties. An access to a RDBMS is not necessarilly public, and the snippet schema above would fail. When designing a schema, it is convenient to make them neutral if they have to be shared ; a private additionnal schema should then cover the non-exportable part that accesses to the RDBMS.
5.3.1 Integration with EXP
As explain before, EXP can be advantageously used to provide complex functions used when initializing typed datas, to specify a counterpart function for a type, or to specify a comparison function. The EXP module defined must be bound to the same namespace URI as the schema. The EXP module where these functions has been defined must be known by the processor instance that unmarshals the schema; see the EXP specification for this purpose, or the chapter about integration with Active Catalog.
In this cases and others, it may be convenient to define macro-functions in EXP.
Additionally, several of this functions could be defined in a module, and a schema could use one or another of this function.
For example, when comparing a polygon, one could:
According to the relevant application, one of this methods or the other could be used. Close to the application, a schema could specify which one use.
Macro functions used as comparison functions
In this example, assume that the type defined previously is labelled geom:polygon-definition, with the variant where x and y are stored in attributes of a point, and with the approriate namespace declarations for the geom and math prefixes (assuming that a math module is also provided).
Within a module definition, the expected functions are declared as macro-functions :
    <exp:extended-function name="geom:compare-points">
        <xcl:set value="{count( $exp:args[1]/* ) - count( $exp:args[2]/* )}"/>
    </exp:extended-function>
    <exp:extended-function name="geom:compare-perimeters">
        <xcl:set value="{geom:perimeter( $exp:args[1] ) - geom:perimeter( $exp:args[2] )}"/>
    <exp:extended-function name="geom:compare-areas">
        <xcl:set value="{geom:area( $exp:args[1] ) - geom:area( $exp:args[2] )}"/>
    <exp:extended-function name="geom:perimeter">
        <xcl:set name="perimeter" value="{number(0)}"/>
        <xcl:set name="pt1" value="{$exp:args[1]/*[1]}"/>
        <xcl:for-each name="pt2" select="$exp:args[1]/*[ position()>1 ]">
            <xcl:set name="p"
value="{$perimeter + math:sqrt( math:sqr($pt2/@x - $pt1/@x) + math:sqr($pt2/@y - $pt1/@y) )}"/> <xcl:set name="pt1" value="{$pt2}"/> </xcl:for-each> <xcl:set value="{$perimeter}"/> </exp:extended-function> <exp:extended-function name="geom:area"> <!--do it yourself--> </exp:extended-function>
The perimeter function could be better : for example, it could test before if the attribute "perimeter" exists and return it, otherwise it performs the computation and set the attribute for other usage.
The first application could use this schema:
    <asl:type compare-with="geom:compare-points" init="void" name="geom:polygon"
parse="{asl:compacted-string(.)}"> <asl:use ref-id="geom:polygon-definition"/> </asl:type>
The second one could use:
    <asl:type compare-with="geom:compare-perimeters" init="void" name="geom:polygon"
Comparison functions as alternative to inner datas
A preceding example was showing a type that converts °F to °C ; this example show an alernative type definition which comparison relies on a macro function.
    <exp:extended-function name="compare-temperature">
        <xcl:if test="$exp:args[1]/unit='°C'">{  }
            <xcl:then>
                <xcl:set name="t1" value="{ $exp:args[1]/value }"/>
            </xcl:then>
            <xcl:else>
                <xcl:set name="t1" value="{ ( $exp:args[1]/value - 32) * 5 div 9 }"/>
            </xcl:else>
        </xcl:if>
        <xcl:if test="$exp:args[2]/unit='°C'">{  }
            <xcl:then>
                <xcl:set name="t2" value="{ $exp:args[2]/value }"/>
            </xcl:then>
            <xcl:else>
                <xcl:set name="t2" value="{ ( $exp:args[2]/value - 32) * 5 div 9 }"/>
            </xcl:else>
        </xcl:if>
        <xcl:set value="{ $t1 - $t2 }"/>
    <asl:type compare-with="compare-temperature" name="temperature"
parse="{asl:compacted-string(.)}"> <asl:sequence> <asl:type item-name="value" ref-type="xs:int"/> <asl:type item-name="unit"> <asl:text value="°C"/> <asl:text value="°F"/> </asl:type> </asl:sequence> </asl:type>
5.3.2 Integration with Active Catalog
There is neither inclusion nor import mechanism in Active Schema. Active Schema doesn't define itself how to retrieve different schema components : it delegates the task to a processor instance that relies itself on catalogs. For this purpose, Active Catalogs are useful because :
Moreover, Active Catalog may be used for other purpose than schema instance retrieval : when defining a schema, it may be useful to define EXP resources (such as functions, as shown before) that will be use in schemata instances.
Here is a snippet Active Catalog instance that bounds a namespace URI to several resources :
    <cat:uri name="http://www.acme.com/geom">
        <cat:entry key="exp:module" value="acme/module.exp"/>
        <cat:entry key="asl:schema" value="acme/schema.asl"/>
        <cat:entry key="asl:schema" value="acme/messages.asl"/>
        <cat:entry key="asl:schema" value="acme/messages-fr.asl"/>
    </cat:uri>
See the Active Catalog specification for further details.
5.3.3 Relationship with Active Datatype
Active Schema allows to define data types with tags, as explained in a previous chapter. However, Active Schema also uses built-in data types ; the Active Datatype specification provides several built-in libraries for data types that may be used in Active Schema, including the well known W3C XML Schema data type library (the Active Datatype specification adapts this library to be used in Active Tags technologies). Built-in data type libraries are pre-compiled schema instances ; a pre-compiled schema instance may contain any material definition : types, attributes, elements... Pre-compiled schema instances
The Active Datatype specification defines an other kind of data type, called marker types, that can't be used in Active Schema instances, but are part of the Active Tags technologies. As this specification is also an Active Tags application, such types can be referred in this document ; just notice that they can't be used as is in Active Schema instances : an Active Schema instance can use only XML-unstructured raw data as specified in the Active Datatype specification.
5.4 Documenting
The <asl:desc> element may be used inside material references and assertions for documentation purposes.
    <asl:attribute
min-occurs="{ 1 - number( count( asl:document()/asl:active-schema/asl:element[ not( @name ) ] ) = 0 ) }"
name="name" type="xs:QName"> <asl:desc id="asl:nameAttrOnTopLevelElem-desc" xml:lang="en"> The top level <at:element>asl:element</at:element> elements must have a <at:attribute>name</at:attribute> attribute, except one of them that can omit it. </asl:desc> </asl:attribute>
Schema client handlers may expose a description if one available instead of an error message when an unexpected content is encountered.
Internationalizing the documentation
The <asl:message> element is a top level element used to redefine multi-lingual messages :
    <asl:message ref-desc="asl:nameAttrOnTopLevelElem-desc" xml:lang="fr">
        L'élément de premier niveau <at:element>asl:element</at:element> doit avoir un attribut <at:attribute>name</at:attribute>,
        excepté pour un seul d'entre eux qui a le droit de l'omettre.
    </asl:message>
    <asl:message ref-desc="asl:nameAttrOnTopLevelElem-desc" xml:lang="x-klingon">
        Dol yor Hoch <at:element>asl:element</at:element> boq <at:attribute>name</at:attribute> choq,
        Dugh bachHa' tuqnIgh chaw' wogh.
    </asl:message>
When a schema client handler needs a description, it may hold an ordered list of preferred languages ; if a message or description exists for the language given, it will be chosen ; otherwise, the description will be used as default language.
Note
Usually, a default language is set on the schema root element with @xml:lang ; each message definition should redefine the @xml:lang value as expected.
Note
Schema designers may find convenient to insert descriptions in a single master language only. Translations could be added in separated Active Schema documents (1 per language).
Additionally, the asl:message() function may be used to format messages. This function can be used in an active sheet to report validation errors.
5.5 Model inconsistency
Users are responsible of their models, and should not deploy them before testing them seriously. For example, the following model will always raise an error when involved, because the first sequence element will consume all <foo> elements, whereas the next sequence element requires one !
    <asl:sequence>
        <asl:element max-occurs="unbounded" min-occurs="0" ref-elem="foo"/>
        <asl:element max-occurs="1" min-occurs="1" ref-elem="foo"/>
    </asl:sequence>
Of course, some schemata may not present such obvious inconsistency.
5.5.1 Non deterministic content model avoidance
A non-deterministic content model is a grammar-based content model where the schema processor has at most one possible choice.
There are no non-deterministic content model in an Active Schema, because the basic processes don't allow such case to happened. The major rule in Active Schemata is that a candidate material matches or doesn't match a primitive model, where its material is read sequencially.
Thus, a write playing is still available in Active Schema to express any arbitrary complex content model, without causing a schema inconsistency.
For example, the familiar following pattern is an unambiguous pattern which is not deterministic and can't be rewritten in a deterministic form :
(odd, even)*, odd?
A DTD containing this declaration would reject it. On the contrary, a valid Active Schema may be written to express the same content model :
    <asl:step max-occurs="unbounded" min-occurs="0">
        <asl:sequence>
            <asl:element
max-occurs="{ number( not( asl:candidate()/preceding-sibling::odd ) or ( name( asl:candidate()/preceding-sibling::*[1] ) = 'even' ) }"
min-occurs="0" ref-elem="odd"/> <asl:element
max-occurs="{ number( name( asl:candidate()/preceding-sibling::*[1] ) = 'odd' ) }"
min-occurs="0" ref-elem="even"/> </asl:sequence> </asl:step>
This step is refactoried as long as there is a candidate element that is alternatively <odd> then <even>. Each time that this step is applied, the sequence model contains a single optional element : alternatively <odd> and <even>.
The following valid Active Schema may also be written to express the same content model :
    <asl:sequence id="odd-even-seq">
        <asl:element max-occurs="1" min-occurs="0" ref-elem="odd">
                <asl:sequence>
                    <asl:element max-occurs="1" min-occurs="0" ref-elem="even">
                            <asl:use ref-id="odd-even-seq" scope="global"/>
                        </asl:interim>
                    </asl:element>
                </asl:sequence>
            </asl:interim>
        </asl:element>
    </asl:sequence>
As long as an element is matched, it is followed by an optional element, alternatively <odd> and <even>.
6 Processing Active Schema
6.1 Invoking Active Schema
A short set of instructions is defined to invoke a schema. These tags have to be used inside an active sheet that is not a schema instance. While running an active sheet, one often need to parse XML documents, validate them, and then transforming them ; the <asl:validate> element has been designed for this purpose.
Schema without namespace URI target
As explained in "integration with Active Catalog", the best way to invoke schemata, is to register them in an Active Catalog and let the engine do the job. However, as this approach is efficient with schemata targetting a namespace URI, it can't be done as is with a schema that has no namespace URI target ; there are 3 ways to deal with such a schema :
Holding schemata
Several storage units (files) may be used to build a schema. Furthermore, a single XML document may be validated by several schemata, for example when several namespaces are used in the instance.
A schema client handler that expects a specific schema, for example to perform a validation on an element, launches a schema request.
Once a schema request is launched, the schema client handler must resolve and hold all storage units (files) that are composing the schema ; the schema client handler must then use the schemata hold for next schema requests.
The schemata are processed in the order in which they have been retrieved ; it is particularly important when using the <asl:apply-definition> element. The tip is to use the catalog as a register that handles schema references ; schemata are unmarshalled only on request, and keep unmarshalled for next usages.
6.2 Batch processing
[TODO]
6.3 Localized validation
[TODO]
Note
Active Sheets may be validate by Active Tags engine while unmarshalling or before unmarshalling. While unmarshalling, only active tags are checked.
6.4 Errors
Errors are categorized in the following types :
Schema client handlers are free to process errors as they want. Errors are just reported informations that denotes that the engine has noticed an unexpected content inside an XML document, regarding to the schemata that have been used by the engine.
[TODO: Draw up the list of standard errors (QName)]
Structured error reports
When validating, a report that holds the errors found is created.
An application that perform validations may use such reports to produce an XML output for specific processing. For example, by transforming it in HTML for an end user, or by transforming it in text for logging. For this purpose, the report provided is a cross operable object that contains informations about the errors :
Building a customized structured error report
    <asl:validate deep="yes" node="{$myNode}" report="myReport"/>
    <xcl:set name="myXMLReport">
        <report>
            <xcl:for-each select="{$myReport/*}">
                <error type="{value( @type )}">{
                    asl:message( value( @reason-id ), '', . )
                }</error>
            </xcl:for-each>
        </report>
    </xcl:set>
Implementations should provide high-level structured error report and XSLT stylesheet to display them in a user-friendly fashion.
7 ASL module reference
ASL : Active Schema Language
ASL namespace URI : http://www.inria.fr/xml/active-schema
Usual prefix : asl
Note
Some features listed here are not used inside a schema, but may appear in other XML documents or active sheets. See externalisable features.
Elements Foreign attributes Predefined properties Extended functions Data types
<asl:active-schema>
<asl:element>
<asl:class>
<asl:attribute>
<asl:item>
<asl:step>
<asl:interim>
<asl:sequence>
<asl:choice>
<asl:select>
<asl:except>
<asl:block>
<asl:use>
<asl:assert>
<asl:text>
<asl:type>
<asl:fallback>
<asl:desc>
<asl:message>
<asl:parse-schema>
<asl:validate>
<asl:candidates>
<asl:report>
@asl:version
$asl:ns-target
$asl:min-occurs
$asl:max-occurs
asl:candidate()
asl:element()
asl:document()
asl:compacted-string()
asl:message()
asl:x-error
Must be an adt:expression that computes an object of the type expected.
Must be a hard-coded value (litteral)
Can be either a hard-coded value or an adt:expression
This material may be missing
Denotes a value to use by default
Allows a read operation.
Allows a write operation.
Allows a rename operation.
Allows an update operation.
Allows a delete operation.
7.1 Elements
<asl:active-schema>
Root element for an Active Schema.
unmarshal phase
The schema handles all definitions found at the top level.
runtime phase
An object of the type asl:active-schema is set to the current object, so that schema client handlers can use it.
Attributes runtime | hard-coded | both
NameTypeValue optional | default value
hard-codedidoptionalxs:QName An identifier that allows the content to be reused.
hard-codedtargetadt:prefix The namespace URI targeted by this schema. A namespace declaration (xmlns:foo="...") must be done for the prefix specified in this attribute (target="foo").
empty The definitions of the schema are not bound to a namespace URI.
hard-codedschema-versionoptionalxs:string The version of this schema.
hard-codedasl:versionoptionalxs:string The version of ASL.
[TODO: content definition]
<asl:element>
The <asl:element> element is both used to define an element, and to refer to one :
[FIXME: An optional '@match' attribute would be very convenient ; it would contain a pattern, and several declarations could be done for the same element. Easy to implement.]
runtime phase
hard-codednameoptionalxs:QName The name of the element.
hard-codedrootoptionalIndicates wether or not the defined element must be root when used, or can be root.
xs:stringalwaysWhen this element is used, it must be root.
sometimesThis element may be root.
neverdefault valueWhen this element is used, it mustn't be root.
bothref-elemoptionalxs:QName The name of an element.
hard-codedref-classoptionalxs:QName The name of an element class.
hard-codedref-nsoptionalA reference to a namespace URI.
xs:string#anyAny namespace URI.
#otherAny namespace URI different of those specified in the host schema.
#localNo namespace URI.
adt:prefix A prefix used in a namespace declaration.
hard-codedmatchoptionaladt:pattern A pattern used to filter elements. When missing, all elements matches the definition. This definition doesn't apply to candidate elements that doesn't match this pattern. Several element definitions may refer to the same element each having a specific pattern. The first pattern matching is applied.
bothmin-occursoptionalIndicates the minimum times the step must be repeated.
xs:nonNegativeInteger1default valueThe step is at least processed once.
xs:nonNegativeInteger The number of times the step must be processed.
bothmax-occursoptionalIndicates the maximum times the step may be repeated.
xs:nonNegativeInteger1default valueThe step is at most processed once.
xs:stringunboundedThe step is processed as long as there is something to process.
xs:nonNegativeInteger The number of times the step may be processed.
<asl:class>
[TODO[A class.]]
<asl:attribute>
The <asl:attribute> may be used :
The <asl:attribute> element is both used to define an element, and to refer to one :
A global attribute definition can be referenced from any other schema. A local attribute definition can be referenced only from the schema that defines it.
runtime phase
hard-codednameoptionalxs:QName The name of the attribute.
bothref-attroptionalxs:QName The name of an attribute.
bothref-typeoptionalxs:QName The name of a type in an attribute definition.
<asl:item>
Defines an item when building a typed data. An item may have a name or may be unnamed.
runtime phase
Opens a context and runs its subactions; builds an item with the data found in the context; feeds the upper context with an item.
hard-codednameoptionalxs:QName The name of the item.
<asl:step>
Set the boundaries of a partial content model. A step may contains substeps. It is a convenient container for primitive content models and other steps. A step is always unstable.
runtime phase
Opens a context and runs its subactions; invoke the schema client handler with the list of matchers found in the context.
<asl:interim>
A container step that denotes that the current content model must be leaved temporarily. The inner models are applied on the next candidates only if the host step has matched. When ending, the host content model goes on (default behaviour). An interim step is always unstable.
runtime phase
hard-codedreplaceoptionalIndicates wether or not the host model must be interrupted or continued, after running the interim step.
xs:stringyesThe interim model replaces the host model that musn't continue.
nodefault valueThe interim model doesn't replace the host model that must continue.
<asl:sequence>
Defines a sequence of elements and/or text content. A sequence is always stable.
runtime phase
Opens a context and runs its subactions; invoke the schema client handler with a sequence of matchers found in the context.
<asl:choice>
Defines a choice of elements and/or text content.
runtime phase
Opens a context and runs its subactions; invoke the schema client handler with a choice of matchers found in the context.
repeatingIndicates how the step must be repeated.
xs:stringstabledefault valueThe content list is kept as is.
unstableThe content list is unstable ; it must be refactoried.
<asl:select>
Defines a list of elements and/or text content to select.
runtime phase
Opens a context and runs its subactions; invoke the schema client handler with a selection of matchers found in the context.
<asl:except>
Draws up a list of exceptions.
runtime phase
Opens a context and runs its subactions; the matchers found in the context are the exceptions for a host matcher.
<asl:block>
Defines a block. This element is very useful when the same definitions have to be reused several times.
runtime phase
Simply runs its subactions.
hard-codedidxs:QName An identifier that allows the content to be reused.
<asl:use>
Uses an identifiable element or its content.
runtime phase
Simply runs the action or the subactions referenced.
hard-codedref-idxs:QName The identifier referenced.
hard-codedscopeoptionalIndicates wether or not the target element must be whole used or only its content.
xs:stringglobalThe element itself is used as is.
contentdefault valueThe element itself is ignored: only its content is used.
<asl:assert>
Checks an assertion. An assertion evaluated to false denotes that the model that uses it fails.
runtime phase
If the assertion is not expressed with the @test attribute, runs its subactions and evaluate the current object as a boolean.
bothtestoptionaladt:boolean The test to compute.
<asl:text>
Defines a text matcher. A text matcher is used to match attribute values and text content. A simple text matcher is defined with one of the following attributes:
[TODO: @list would be convenient to match list of text values (by handling an 'adt:list' typed data) ; easy to implement]
A complex text matcher refers to a type either with the @ref-type attribute, or with a type defined within; in this last case, the text matcher can't have an interim step.
runtime phase
Opens a context and runs its subactions.
Feeds the upper context with a text matcher.
bothvaluexs:string A text value.
hard-codedmatchxs:string A regular expression.
hard-codedref-typexs:string A reference to a type.
hard-codedcanonical-equivalenceoptionalEnables or disables the canonical equivalence of a regular expression, that is to say that two characters will be considered to match if, and only if, their full canonical decompositions match; for example, the expression "a\u030A" will match the string "å".
xs:booleantrueenables the canonical equivalence.
falsedefault valuedisables the canonical equivalence.
hard-codedcase-insensitiveoptionalIndicates wether a regular expression is case-sensitive or not.
xs:booleantrueenables case-insensitive matching.
falsedefault valuedisables case-insensitive matching.
hard-codeddot-alloptionalIndicates wether or not a regular expression enables dotall mode. In dotall mode, the expression . matches any character, including a line terminator.
xs:booleantruematches line terminators.
falsedefault valuedoes not match line terminators.
hard-codedmutli-lineoptionalIndicates wether or not a regular expression is in multi-line mode. In multiline mode the expressions ^ and $ match just after or just before, respectively, a line terminator or the end of the input sequence.
xs:booleantrue^ and $ doesn't match at the beginning and the end of the entire input sequence.
falsedefault value^ and $ matches at the beginning and the end of the entire input sequence.
hard-codedignoreIndicates wether this matcher must build an item or not.
xs:stringyeswhen matched, the host typed data remains unchanged.
nodefault valuewhen matched, this matcher builds an item on behalf of the host typed data.
bothitem-namexs:QName The name of the item to build.
runtimeitem-valueany The value of the item to build.
<asl:type>
Defines a data type.
The <asl:type> element may be used :
When the type to define is based on an another type (@base), it is possible to specify how to initialize (@init) the typed data before parsing, and what to parse (@parse).
A type is defined with steps that draw up lists of text matchers and other type matchers.
unmarshal phase
A type definition may be registered to the schema either by name or by ID:
runtime phase
invokation phase
A type matcher is invoked when a text candidate must be checked. For this purpose, it opens a context and runs its subactions. The context is used to build the typed data. If the text candidate matched the type, the typed data feeds the upper context.
Note
Errors raised by a type may be ignored by the schema client handler : when a type matcher failed to match a text data, another candidate type matcher may be used; an error is raised only when a candidate matcher is expected and that none matched.
hard-codednameoptionalxs:QName The name of the type.
hard-codedbaseoptionalxs:QName The name of a base type.
runtimeinitoptionalIndicates how to initialize the typed data before parsing. If this attribute is missing, the typed data is initialized with the typed data produced by the base type if it is a composite data or wrapped in a composite data.
void the typed data is not initialized; when processing the subactions, if a type initializes its typed data, it will supply it to its parent type.
any the object is used to initialize the typed data.
runtimeparseoptionalIndicates what to parse after initialization. If this attribute is missing, the type will parse the remainder that has not been parsed by the base type.
xs:string the text that this definition have to parse.
hard-codedcompare-withoptionalxs:QName The name of a function. This function is automatically involved when a data of this type is involved in comparison operations in XPath expressions.
hard-codedparse-withoptionalxs:QName The name of a function. The function is involved to transform a data to a typed data of this type when this type is required. [FIXME: cast-with() is it a better attribute name ?]
Indicates to the schema client handler to apply the definitions of the next schema. The schemata list is built from catalogs and maintained by the schema client handler.
<asl:fallback> elements may be used within to indicate which foreign elements and attributes are authorized when applying definitions.
<asl:fallback>
A fallback matcher is used when an unexpected material (element or attribute) has been encountered when applying definitions (<asl:apply-definition>).
hard-codedmatchadt:pattern
The pattern to match. If an unexpected material doesn't match any <asl:fallback> element, an error is raised.
hard-codedmodeoptionalIndicates what to do with the unexpected material (element or attribute).
xs:stringignorethe material is considered absent
skip(for elements only) the content of the element is considered to hold its place
traversedefault valuethe material and its content or value is checked
<asl:desc>
A description.
<asl:message>
An alternate message definition. This element is designed for multilingual support. When a <asl:desc> element is used in a schema, the current language specified with the @xml:lang is endorsed. The <asl:message> redefines any description in one or more languages (use 1 message element per language). It may be convenient to define a set of messages in a separate unit storage (file), usually 1 set of messages per language.
hard-codedref-descxs:QName The description referenced.
7.2 Foreign attributes
@asl:version
The version of the ASL module to use. This attribute should be encountered before any ASL element, but it takes precedence on the element inside which it is hosted.
7.3 Predefined properties
$asl:ns-target
  • Property type: xs:anyURI
  • $asl:ns-target is the target namespace URI of the schema.
    $asl:min-occurs
  • Property type: xs:int
  • $asl:min-occurs is the value of the min occurs value computed.
    $asl:max-occurs
  • $asl:max-occurs is the value of the max occurs value computed.
    7.4 Extended XPath functions
    asl:candidate()
  • Return: xml:node
  • This function returns the candidate material to check or to insert, according to the using mode of the schema. However, if it is an element, it has no name because in an insert mode, the host application may use the schema to guess the list of elements available in the insert context.
    In fact, the candidate material can be used only for positional testing.
    asl:element()
  • Return: xml:element
  • This function returns the element designated by the @name attribute used in the <asl:element> element.
    asl:document()
  • Return: xml:document
  • This function returns the document hosting the element or attribute that is processing by the schema.
  • Return: xs:string
  • Returns the compacted form of a string, that is to say a string with no trailing spaces and for which contiguous spaces are replaced with a single space.
    Arguments
    1xs:string The string to compact.
    Arguments
    1other The string value of the object will be compacted.
    7.5 Externalisable features
    The following items are not designed to be used inside an Active Schema, but inside an active sheet that is not a schema, that would use and refer to schemata.
    <asl:parse-schema>
    Parses a schema.
    bothnameoptionalxs:QName The qualified name of the schema property to create.
    runtimesourceio:x-file The schema file to parse.
    io:input The input stream schema to parse.
    xs:anyURI The URI of the schema to parse ; the schema will be looked up by the catalog known by the host processor instance. If the schema is stored in several storage units (files), the schema returned may be linked to all schema instances returned by the catalog. If a definition is expected on this schema and not found, the schema client handler will use the catalog for further lookup.
    xml:document The XML document to unmarshal to a schema instance.
    <asl:validate>
    Instruction used to perform a validation of a schema on a node. If no schema is specified (with the @schema attribute), the validation is performed with the schema found in the catalog known by the host processor instance
    runtimeschemaoptionalasl:schema The schema instance to use.
    xs:anyURI The URI of the schema file to parse.
    runtimenodexml:node
    The node to validate.
    bothreportxs:Qame
    The name of the report property to produce. A property with this name is added to the data set. A report is a adt:list of asl:x-error.
    hard-codeddeep Indicates whether a recursive validation must be performed or not.
    xs:stringyesPerform a recursive validation.
    nodefault valuePerform a surface validation.
    hard-codedaugment Indicates whether the infoset must be augmented with typed datas or not.
    xs:stringyesTyped datas are bounded to nodes defined with a type.
    nodefault valueTyped datas are used only for checking.
    <asl:candidates>
    Instruction used to identify the material available on the given context. [TODO]
    <asl:report>
    This element does nothing. It is an element container for canonical paths, and should not be hard-coded inside an active sheet. However, it could be generate anyway in an XML document and used by an application.
    When created, this element contains all namespace declarations expected in the path, hosted either in the @path attribute or in the @rule-path attribute.
    See "path element" and asl:x-error.
    runtimepathoptionalxs:string A canonical path.
    runtimerule-pathoptionalxs:string A canonical path.
    asl:message()
  • Return: xml:node
  • Build a structured message with the object given. The message may be built with the locale language or with a specific language.
    If no object is specifically provided, the object given is the current object when building the structured message.
    Arguments
    1xs:QName The message ID.
    Arguments
    2xs:string The language.
    Arguments
    2xs:string The language or an empty string to force locale usage.
    3an object The object to use in the message.
    asl:x-error type
    Errors are created when performing a validation on an XML instance.
    Operation read | write | rename | update | delete
    TypeValueComment
    type()
    xs:QNameasl:x-errorThis type
    string()
    readxs:string The string value of an error is [FIXME: what ?].
    attribute::
    readadt:map of xml:attribute A set of attributes (see below). Additional attributes may be set as specified in this specification. Any of the following predefined attributes may be shadowed by a specific one with the same name ; if removed, the original predefined attribute is unshadowed.
    @source-document
    readxml:document The XML document that host the node that was checking.
    @schema
    readasl:schema The schema that raised the error.
    @node
    readxml:node The node that was checking.
    @candidate
    readxml:node The candidate material in use, if any.
    @path
    readxml:node The path element of the candidate or the node that cause the error.
    @rule-path
    readxml:node The path element of the schema rule that raise the error.
    @reason-id
    readxml:node The key of the error message.
    @type
    readxml:node The key of the type of error.
    Note
    Path element
    The canonical path of a node is hosted in an attribute of the <asl:report> element (the @path or @rule-path attribute), called a path element.
    This element contains the namespace declarations involved in the path.
    The path is exposed as an expression to make easier use by an application.
    Appendix
    A Glossary
    B Related Active Tags specifications
    C Common Active Tags modules
    This list is not exhaustive; it is a list of common modules usable by an engine that implements the Active Tags specifications that implementors may use. Additional modules are welcome.
    D Lists
    D.1 Examples list
    D.2 Figures list
    E Active Schemata for ASL
    E.1 ASL definitions
    [schema.asl]
    <asl:active-schema asl:version="1.0" target="asl" schema-version="1.0" xml:lang="en"
        xmlns:adt="http://www.inria.fr/xml/active-datatypes"
        xmlns:xs="http://www.w3.org/2001/XMLSchema-datatypes"
        xmlns="http://www.w3.org/1999/xhtml"
        xmlns:at="http://www.inria.fr/xml/active-tags/reference">
        <asl:attribute name="asl:version" min-occurs="0" ref-type="xs:string"/>
        <asl:element name="asl:active-schema" root="always">
            <asl:block id="asl:commonAttributes-block">
                <asl:attribute ref-ns="#other" min-occurs="0" max-occurs="unbounded"/>
                <asl:attribute name="id" min-occurs="0" ref-type="xs:ID"/>
            </asl:block>
            <asl:attribute ref-attr="asl:version"/>
            <asl:attribute name="schema-version" min-occurs="0" ref-type="xs:string"/>
            <asl:attribute name="target" ref-type="att:ns-prefix"/>
            <asl:choice min-occurs="1" max-occurs="unbounded">
                <asl:element ref-elem="asl:element"/>
                <asl:element ref-elem="asl:class"/>
                <asl:element ref-elem="asl:attribute"/>
                <asl:element ref-elem="asl:text"/>
                <asl:element ref-elem="asl:block"/>
                <asl:element ref-elem="asl:type"/>
                <asl:element ref-elem="asl:message"/>
            </asl:choice>
        </asl:element>
        <asl:block id="asl:occurs">
            <asl:attribute name="min-occurs">
                <asl:text ref-type="xs:nonNegativeInteger"/>
                <asl:text ref-type="adt:expression"/>
            </asl:attribute>
            <asl:attribute name="max-occurs">
                <asl:text value="unbounded"/>
            </asl:attribute>
        </asl:block>
        <asl:type name="asl:dynQName" parse-with="qname">
            <asl:desc id="asl:dynamicQName-desc">A dynamic QName is either hard-coded or computed at runtime.</asl:desc>
            <asl:type ref-type="xs:QName"/>
            <asl:type ref-type="adt:expression"/>
        </asl:type>
        <asl:element name="asl:element">
            <asl:use ref-id="asl:commonAttributes-block"/>
            <asl:attribute name="root" min-occurs="0" default="never">
                <asl:text value="always"/>
                <asl:text value="sometimes"/>
                <asl:text value="never"/>
            </asl:attribute>
            <asl:select min-occurs="{ 1 - count( asl:element()/parent::asl:active-schema ) }"
    max-occurs="{ $asl:min-occurs }"> <asl:desc id="asl:refAttrOnTopLevelElem-desc"> Non top level <at:element>asl:element</at:element> elements must have one of the following attributes : <at:attribute>ref-elem</at:attribute>, <at:attribute>ref-class</at:attribute>, or <at:attribute>ref-ns</at:attribute>. </asl:desc> <asl:attribute name="ref-elem" ref-type="asl:dynQName"> <asl:interim> <asl:select min-occurs="0" max-occurs="2"> <asl:use ref-id="asl:occurs"/> </asl:select> </asl:interim> </asl:attribute> <asl:attribute name="ref-class" ref-type="xs:QName"> <asl:interim> <asl:select min-occurs="0" max-occurs="2"> <asl:use ref-id="asl:occurs"/> </asl:select> </asl:interim> </asl:attribute> <asl:attribute name="ref-ns"> <asl:block id="asl:ref-ns"> <asl:type ref-type="adt:prefix"/> <asl:text value="#any"/> <asl:text value="#other"/> <asl:text value="#local"/> </asl:block> <asl:interim> <asl:select min-occurs="0" max-occurs="2"> <asl:use ref-id="asl:occurs"/> </asl:select> </asl:interim> </asl:attribute> </asl:select> <asl:attribute name="name" ref-type="xs:QName"
    min-occurs="{ count( asl:element()/parent::asl:active-schema and asl:root()/asl:element[ not( @name ) ] ) }"
    max-occurs="1"> <asl:desc id="asl:nameAttrOnTopLevelElem-desc"> The top level <at:element>asl:element</at:element> elements must have a <at:attribute>name</at:attribute> attribute, except one of them that can omit it. </asl:desc> </asl:attribute> <!--TODO : content definition--> </asl:element> <asl:element name="asl:attribute"> <asl:use ref-id="asl:commonAttributes-block"/> <asl:use ref-id="asl:occurs"/> <asl:attribute name="name" ref-type="xs:QName"
    min-occurs="{ count( asl:element()/parent::asl:active-schema ) }"
    max-occurs="1"> <asl:interim> <asl:select min-occurs="0" max-occurs="1"> <asl:attribute name="ref-type" ref-type="asl:dynQName" min-occurs="0"/> </asl:select> </asl:interim> </asl:attribute> <asl:attribute name="ref-attr" ref-type="asl:dynQName"
    min-occurs="{ 1 - count( asl:element()/parent::asl:active-schema ) }"> </asl:attribute> <asl:attribute name="ref-ns"> <asl:use ref-id="asl:ref-ns"/> </asl:attribute> <!--TODO : content definition--> </asl:element> <asl:element name="asl:type"> <asl:attribute ref-ns="#other" min-occurs="0" max-occurs="unbounded"/> <asl:attribute name="name" min-occurs="{ count( asl:element()/parent::asl:active-schema ) }"
    max-occurs="{ $asl:min-occurs }" ref-type="xs:QName"/> <asl:attribute name="id" max-occurs="{ 1 - count( asl:element()/parent::asl:active-schema ) }"
    min-occurs="{ $asl:max-occurs }" ref-type="xs:ID"/> <asl:attribute name="base" ref-type="xs:QName" min-occurs="0" max-occurs="1"> <asl:interim> <asl:select min-occurs="0" max-occurs="2"> <asl:attribute name="init" ref-type="adt:expression" min-occurs="0"/> <asl:attribute name="parse" ref-type="adt:expression" min-occurs="0"/> </asl:select> </asl:interim> </asl:attribute> <asl:attribute name="compare-with" ref-type="xs:QName" min-occurs="0"/> <asl:attribute name="parse-with" ref-type="xs:QName" min-occurs="0"/> <!--TODO : content definition--> </asl:element> <asl:element name="asl:item"> <asl:use ref-id="asl:commonAttributes-block"/> <asl:attribute name="name" ref-type="xs:QName" min-occurs="0" max-occurs="1"/> <!--TODO : content definition--> </asl:element> <asl:element name="asl:apply-definition"> <asl:use ref-id="asl:commonAttributes-block"/> <!--TODO : content definition--> </asl:element> <asl:element name="asl:fallback"> <asl:use ref-id="asl:commonAttributes-block"/> <asl:attribute name="match" ref-type="adt:pattern"/> <asl:attribute name="mode" min-occurs="0"> <asl:text value="ignore"/> <asl:text value="skip"/> <asl:text value="traverse"/> </asl:attribute> </asl:element> <!-- TODO --> </asl:active-schema>
    E.2 General purpose messages
    [messages.asl]
    <asl:active-schema asl:version="1.0" xcl:version="1.0" target="asl" schema-version="1.0"
    xml:lang="en" xmlns:asl="http://www.inria.fr/xml/active-schema" xmlns:xcl="http://www.inria.fr/xml/active-tags/xcl" xmlns="http://www.w3.org/1999/xhtml" xmlns:at="http://www.inria.fr/xml/active-tags/reference"> <!-- error messages for validation --> <asl:message id="asl:attributeExpected"> The <xml:attribute>{ name( value( @candidate ) ) }</xml:attribute> attribute is missing in the <xml:element>{ name( value( @node ) ) }</xml:element> element. { value( @path ) } Schema : { string( @schema-ns ) } { value( @rule-path ) } </asl:message> <asl:message id="asl:unexpectedAttribute"> The <xml:attribute>{ name( value( @candidate ) ) }</xml:attribute> attribute is unexpected in the <xml:element>{ name( value( @node ) ) }</xml:element> element. { value( @path ) } Schema : { string( @schema-ns ) } { value( @rule-path ) } </asl:message> <asl:message id="asl:badAttributeValue"> Bad value = "{ string( value( @candidate ) ) }" for the attribute <xml:attribute>{ name( value( @candidate ) ) }</xml:attribute> in the <xml:element>{ name( value( @node ) ) }</xml:element> element. { value( @path ) } Schema : { string( @schema-ns ) } { value( @rule-path ) } </asl:message> <!-- TODO --> </asl:active-schema>
    F Known implementations
    This list is not exhaustive. Additional implementations are welcome.
