The Gephi Semantic Web Import plugin is intended to allow the import of semantic data into Gephi for graph visualization and analysis ; see also the screencasts of demos from the Wimmics research team.
The imported data are selected and constructed by processing a SPARQL query on one or several sources. The data can be queried and imported using three ways:
The plugin also provides the following functionalities: statistics on the types present in the rdf obtained (if the rdf:type relations are provided in the construct request) ; a filter on the type of the nodes; a generic filtering mechanism on the nodes, based on a SPARQL "Select" queries; scripting capabilities in java and python for batch processing.
